We are trying to create a survey in Survey123 Connect where a score is assigned based on user choice for a select_one type question in an integer type following the question. The issue we are having is that we are only to generate scores for 2 of the questions depending on the calculation formatting. See screenshots below as well as the calculation used in the integer type. Any suggestions would be greatly appreciated
if(${a2o_1}="yes",${c2},${c1}) or if(${a2o_1}="yhi",${c3},${c1}) or if(${a2o_1}='no',${c1},${c1})
Solved! Go to Solution.
Oop, I see what I did there, i was pointing to the questions not the the integer
