Assign score based on Select one question type, can only score 2 of three answers
4538
10
03-20-2023 08:41 AM
DanielChelist
We are trying to create a survey in Survey123 Connect where a score is assigned based on user choice for a select_one type question in an integer type following the question. The issue we are having is that we are only to generate scores for 2 of the questions depending on the calculation formatting. See screenshots below as well as the calculation used in the integer type. Any suggestions would be greatly appreciated
if(${a2o_1}="yes",${c2},${c1}) or if(${a2o_1}="yhi",${c3},${c1}) or if(${a2o_1}='no',${c1},${c1})
DougBrowning
You cannot use or inbetween if statements like that.  You need to use the else in the if.  Looking at your options I think this would work and be simpler.
if(${a2o_1}="yes",${c2}, if(${a2o_1}="yhi", ${c3}, ${c1}))
This assumes it will never be blank.
Hope that helps
DougBrowning
Hope that helps
DanielChelist
That did the trick, thanks Doug!
DanielChelist
so, if I wanted to sum the results from multiple questions, what would be the proper syntax for that?
ex
${a2o_1}+${a2o_2}...
DougBrowning
Yes typically that is what I do.  One line for each sum then one master that sums them all up.  Set the bind type field to int so you get a number and not a string.  Can also set the temp fields bind esri type to null and they will stay out of the feature service.
DanielChelist
hmm, I must be doing something wrong. Getting an empty output with the following. Same empty output with parenthesis around the calculation
DougBrowning
Are those 3 fields set to bind int?
DanielChelist
I believe so, yes 
DougBrowning
Yes that looks right.  At this point just post the form or just guessing.
DanielChelist
Good call, see attached, thanks
