appearance
1585
06-26-2022 10:50 PM
DrJumaKhudonazarov
Can I elect 2 appearances. for instance  minimal and autocomplete ? If I have  list of say  100 medicines  I want them minimal and autocomplete?
DougBrowning
Yes just have both with a space in-between.  It may give a warning but it will work.
DrJumaKhudonazarov
Thanks, tried  didn't work  at all.
DougBrowning
autcomplete is already minimal with the drop down really.  So what are you expecting vs what you see.  What is the exact thing you are trying.  With no screen shots or samples it is hard to help.
DrJumaKhudonazarov
Thanks. I have a list of 45  items that I need to use as a multiply selection so I want to type 3 letters of the items and the full name should appear. Drop down give you only 1 option  autocomplete or minimal, you cant select both and i tried to underscore it is not working
