Appearance Search Help
619
06-02-2023 11:54 AM
mstranovsky
Is there a way to filter a select one list that is using appearance search that has more than the maxRecCount based on the first character typed into the question? For instance if I have a select_one question that is based on a feature layer of street names, can I filter the list based on the first character that is typed into the question, like street names that begin with the letter "R"?
Nicole_Ueberschär
You can combine the search appearance with autocomplete (even recommended here https://community.esri.com/t5/arcgis-survey123-blog/dynamic-choice-lists-using-search-appearance/ba-...). In one of the comments I saw that you just put "autocomplete search(...)" as appearance. Is that what you need?
