Annotate different web maps in single survey?
1957
08-03-2022 10:32 PM
COSPNWGuy
Simple question. I'd like to build a survey that allows users to annotate different maps (pre-built web maps with different layers), based on their answer to a previous question. Is this workflow possible? If so, how? It seems like you can only annotate image questions, and while you can define the body::esri:style method as "map", you can't define what map to use.
m3
In the documentation for body::esri:style it says you can use
map=mapID
It also says you can use multiple methods in body::esri:style such as
backgroundColor="red" borderColor="blue"
However in practice it does not seem to work with
method=camera,browse,map map=mapID
or any other combination.
It causes some sort of undisclosed error that loads none of your linked basemaps or defaults the the ESRI Topo or whatever the default map is.  You can also load other ESRI basemaps.
Seems like a bug or perhaps they haven't implemented multiple body::esri:styles for annotations.
If you just use
the user can choose the basemap from the basemap gallery button
HTH
COSPNWGuy
Tagging @IsmaelChivite, Survey123 legend for any advice on this one.
m3
I also noticed that eventually all custom basemaps stop loading eventually (after the 3rd or 4th time) unless you force quit S123 and restart it.  Probably not the kind of workflow you would want to instruct field crews on.
That could be all that's going on in my first reply, that the maps just eventually don't load.
m3
@IsmaelChivite
Wondering if there's any help on this.  Different maps still aren't behaving properly.
