Hi everyone,
I’m trying to use the new AI-powered audio analysis in a Survey123 Connect form, but I can’t get it to work.
I tested the same setup in Survey123 Web, and it works amazingly well there. However, when I use the form in Survey123 Connect, the AI audio transcription does not work.
This is the expression I’m using:
I have several existing Survey123 Connect projects and would love to add this new AI-powered audio analysis to them.
Could someone please let me know if I’m missing something, or if this feature is currently supported only in Survey123 Web? I’ve attached my form for reference.
Thanks so much!
As per Survey123 analysis tools (beta):
To use the image analysis tool (beta), the following must be configured by an ArcGIS organization administrator:
EDIT NOVEMBER 2025 - text analysis and audio transcription are now also in beta. Learn more here, Make your Survey123 forms smarter with AI-powered image, text, and audio analysis
