Add signature from survey to power automate template
613
05-01-2023 03:37 PM
BigLouC
Good evening,
I have created a word template on one drive to use with power automate to get information from a survey.
One of the items I need is the signature on the template from the signature collected with the survey.
I cant see to find a way to enter the signature on the template and not as an attachment.
Has anyone been able to complete this task?
IsmaelChivite
Esri Notable Contributor
I am not sure I completely follow your question here. It seems like you have a signature question in a Survey123 form and you want to create a report in PDF format that includes the signatures collected.
The Survey123 report syntax to include a signature in your PDF output would look something like this:
${my_signature_question | size:400:0}
The above would take the signature in the question named my_signature_question and represent it as an image of 400 pixels in width.
CCGIS
Hello @IsmaelChivite,
Thank you for your post. I have tried using different options to show the signature in a report, and this syntax shows True
I created my survey using survey123 online and then edited it in Connect. I see the signature as an Attachment. Do I need to somehow convert it from an attachment to an image to include it in the report?
Thank you.
Claudia
