Add graphics and images to survey questions
959
09-14-2022 10:11 AM
BrandonCrafword
Howdy,
I'm trying to add a simple graphic of a map to one of my survey123 questions. I see there's an option under the "File" group for an "image" question, but that appears to be geared toward survey participants uploading the image for their answer. I just want to add my own images to supplement and illustrate locations that we're asking questions about. I know a webmap might also be an option, but I already have the jpegs/pngs that I'd like to use, so it'd be nice if there's a way to simply upload those to accompany certain questions.
Thank you
DougBrowning
MVP Esteemed Contributor
Add the photo to the media folder then you can name it in the media::image column for a question and you can do it on the lists as well.   
If the image is large what I do is wrap it in a group - it is out of the way until the user needs it.
 Hope that helps
MichelleWilliamsERM
Do you want the same jpg for ALL surveys? If so, then this would work for you.
Add your jpg to the media folder; the jpg name should not have spaces.
survey123_solutions
This video by Ismael Chivite.shows how to.do it. Just add images to your media folder and then name the images in your xls.
In the video, fast forwsed to about 1 hour and 5 min into the video. Best of luck!
https://youtu.be/vECznnoJHGk
