1.2.82 Integer field required by default
3752
03-03-2016 09:23 AM
BridgetteKelly
I have just updated to version 1.2.82 and I am also still having the problem of an Integer field in the xls form being required by default. The name of my integer filed is "Ticket Number", so when I try to send a form where the integer filed is not filled out, I get the error: Ticket Number:input is invalid
DeniseKing
New update for Survey123 for ArcGIS is now available in the Google Play and iTunes stores. For details, please see GeoNet post for Survey123 for ArcGIS 1.2.89 critical update, 1.2.89: Critical Update to the Survey123 mobile app .
WesMiller
Regular Contributor III
You may get an answer quicker in Survey123 for ArcGIS
IsmaelChivite
Esri Notable Contributor
Hi Bridgette,
  Thanks for your feedback. We have identified the issue and have a fix which is undergoing certification testing.  This issue is critical and will issue a special update for the apps as soon as we can.  Similar behavior occurs in 1.2.82 and 1.2.77 with decimal questions. Both issues will be resolved soon!
Ismael
DeniseKing
