Survey123 bug: dates in February are not retained, but changed for dates in March
448
08-30-2022 02:25 AM
Status: Open
Labels (2)
HélèneTouyéras
Occasional Contributor II
Hi Survey123 friends, users, and developpers,
On of my users points out a defect in date collection, in the Survey123 FielApp (whether mobile or PC): entering a date in February replaces the date for the same date in march.😯
Correcting the value allows keeping the correct date in February, as long as the field is not emptied using the cross at thr right-hand-side of the field:
  • correcting the filled field retains the value,
  • but a new value collected in an empty field is systematically erroneous
I attach a video of the observed defect.
I observe this behaviour only on Survey123 apps (Field App and Survey123Connect): it does not occur when filling or designing web forms.  (However, a form designed with the web designer and that is filled on the field app will have this behaviour).
Tested apps include:
- Field App on PC (64bits, Windows 10 21H2) , v. 3.15.156 & 3.13.246 ;
-Mobile App (android 11), v3.13.246 and v3.15.156
-Survey123Connect: v3.25.175
Attached a simplistic Survey123 Connect form XLS with the one date field.
Many thanks, ESRI-Team for your forthcoming action on this issue!
With kind regards,
Hélène.
1 Comment
HélèneTouyéras
This strange behaviour has stopped after a few weeks, as unexpectedly as it started, and our Survey123 went back to normal.
No explanation why - it just happened. 👻
