"Popup" question/groups/repeats to access at any time in the survey.
412
09-29-2025 10:52 AM
Status: Open
Labels (2)
AlfredBaldenweck
MVP Frequent Contributor
I think it would be really neat if you could have a "floating" question that you could pull up whenever, regardless of where you are in the survey.
For example, if you are required to take a picture and a point of a hazard whenever you find one, but it's one of many questions in a survey that stretches across more than one page.
Rather than having to go back (or forward) to that question, if you could click on a little button and open it as a popup, that would be neat.
My vision for this is one or both of the following:
  • A floating bar with thumbnails pointing to the question/group/repeat
  • A little button next to certain questions to launch whatever relevant question/group/repeat as necessary.
The closest workaround I can think of right now is doing like, a page set up and having the question outside of each page group. This leads to the question being on every page. I often use this for notes or image questions. The downside of this is that it doesn't work with repeats, which are very important for most of my workflows.
Please add the ability to make questions/groups/repeats available as a popup window to be accessed at any time during survey completion.
1 Comment
LindsayRaabe_FPCWA
I think this is a great idea.I hadn't found it previously, but can see the value in being able to pull up a question or set of questions from any point in the survey, and to pass values into that set of questions from any point in the survey too - not just launch/open the popup.
