To see in the survey a number that contains thousands separated either by point or by spaces, so that at the time of seeing the result it is easier to read the digit.
Example: Currently the field results in 6948390, I would like to see it as 6 948 390.
Use in the field of appearance the following function "thousands-sep" however I do not have the desired result.
