I'm using a repeat to pull data from a feature service about current projects. I'm then using Concat to create a list of the projects in my main data layer. I want the ability to create surveys that have the ability to pull data into repeats, but not actually create the related table or any of the fields when I got to publish the survey. Just be able to use it as an intermediary for calculations.
Could you elaborate some one this?
A "null" value intrinsically has no value. So, publishing "nothing" doesn't really make a lot of sense. If you want the data to be stored, why not store it as a Text field with the Hidden appearance?
