Add JavaScript syntax highlighting in Survey123 Connect script editor
1126
03-23-2022 01:13 PM
Status: Open
Katie_Clark
MVP Regular Contributor
As the title says....adding syntax highlighting would (hopefully?) be a fairly small change but extremely useful when making small edits to scripts in the Survey123 Connect interface. I have found it often works smoother to edit the scripts within Connect, rather than a separate IDE that does offer syntax highlighting.
As we can see, right now it's all just black text, which isn't as easy to visually parse out.
1 Comment
jcarlson
That would be pretty nice!
Currently, I use VS Code for this, and I just have a workspace that connects to the My Survey Designs folder so that I can access any of the forms' scripts, but there are certainly times when I'd rather edit the script in Connect.
