Ability to zoom in on choice images in Survey123
1082
09-02-2020 07:00 AM
Status: Open
DougBrowning
MVP Esteemed Contributor
When using images in a select one (or select multiple) you see a little thumbnail then can tap and make it bigger.  That works great.
But you cannot zoom in at all on the image when it is full page.  Is there any plans to enable this?   We have some image choices where a zoom in would be really handy.
Thanks
3 Comments
ChrisMaclaurin
This would also be good for the 'image' type question (embebd images in survey form). We sometimes like to refer to historic fieldsheets which I have found our surveyors in the field find handy... but somethimes they are quite small and the ability to zoom in on these images would be handy.
EricaCirigliano
This is also needed when adding an image via the image::media column to a note. So many use cases!
EmmaWhite5
I am using the survey123 app with an SVG image in the media::image column. The image is a map with a clickable grid over it. The form is publicly available so users vary. It would be much easier for some users to choose a square on the grid if they had the ability to zoom in on the image. Thanks!
