Storymap: Need smaller zoom increments--maps in sidecar
1503
5
09-13-2023 04:04 PM
lzk222
The zoom in/zoom out buttons steps are too large. At one zoom level political boundaries are too small, at the the next level they are cut off...I need an in between zoom level. Any suggestions on how to do this? This is for a map in a sidecar Storymap element, but is a general issue for all webmaps/experiences.
KathrynHailes
I too have this problem all of the time.  It would be fantastic if there was a way around this limitation.
OwenGeo
Esri Notable Contributor
Thanks for sharing this feedback! There isn't a way to set a specific scale at this time. Also, it's worth mentioning that even if you could set a specific scale, all readers may not get the exact experience you expect since sidecar media panels are responsive, which means they can be different sizes/aspect ratios depending on the screen size/shape the story is viewed on.
There are some additional configuration options we could consider to provide more fine-grained control over the map extent/zoom level, but there are some tradeoffs we'll need to think through. I'd encourage that you submit an idea on the ArcGIS StoryMaps Ideas Board so others can upvote this idea and provide additional information about how it might be valuable to them.
Owen Evans
lzk222
Thanks @OwenGeo. On this somewhat different but relevant topic, would it be possible to set zoom level based on original extent? Right now it seems like zoom level stays constant across devices where what should stay constant is the extent of the original map. Building off this, could it be possible to create an enhancement where boundary of display feature (Nevada, in my case) is set such that no matter what the screen size the preset boundary is always fully displayed?
Alternatively, and probably more realistically, would it be possible to add feature where zoom level can be customized for various device screen sizes? Experience builder provides many different screen size previews. Something akin to this but with the option to actually set the zoom for each one. Right now I don't see an option to even preview StoryMaps in other screen sizes, never mind setting a customized initial view.
Lukas
lzk222
Maybe this is semantics, but I don't think the issue is scale. It's zoom level. ESRI zoom in/out buttons seem to be configured for only whole integer steps. Whereas what I'm seeking is a modification to the zoom in/out buttons that allow for half or quarter integer steps. E.g. Google Maps. zoom_levels_quarters_google_maps.gif
It may be hard to see, but the z level in the url goes from 13z to 13.25z. This is the gradation I'd like to see in ESRI online maps which, in this example, would only be able to go from 13z to 14z.
lzk222
To highlight just how frustrating this is.
How the storymap displays to me (1920 x 1080).
How it displays to my boss (1024 x 768) 😕
