ArcGIS StoryMaps Questions
169
17.9M
1.3K
| Open | When using a sidecar:It would be great to explore the map, zoom and pan around, and then use media actions to be able... by C_McNamara Frequent Contributor 0 0 | 0 | 0 | |
| Needs Clarification | Feature requestsIncrease the maximum number of headings displayed in the navigation panel (currently limited to 30) t... by TomášHolomek Observer 0 1 | 0 | 1 | |
| Under Consideration | I'm loving the new beta pictograph infographic feature but limiting the pictograph element to only one category/icon ... by dcrGIS_asimm Occasional Contributor 1 1 | 1 | 1 | |
| Open | Hello!I've been experimenting a lot with making portfolios in StoryMaps - it would be helpful to have a way to add a ... by SaraJL Frequent Contributor 1 0 | 1 | 0 | |
| Open | The new Categories function in map tours is great, but when you click on a feature on the map, it requires you to cli... by johnjcarter Occasional Contributor 4 0 | 4 | 0 | |
| Open | ArcGIS StoryMaps are increasingly being used as an educational tool at my institution because they do a great job of ... by IckFin Occasional Contributor 4 0 | 4 | 0 | |
| Under Consideration | It would be nice to be able to change the panel size within a map tour similar to the options in a sidecar. This wou... by LoreyStinton Occasional Contributor 1 3 | 1 | 3 | |
| In Product Plan | As accessibility has become an ever more required element of our work, we'd like to request that the use of AI to gen... by Willen Occasional Contributor 1 2 | 1 | 2 | |
| Under Consideration | Currently you can specify a story URL that a user should be directed to when viewing a StoryMap item. This is in a St... by PeterKnoop 3 5 | 3 | 5 | |
| Open | Please add support for saving a dark themed StoryMap to a PDF with its intended dark theme appearance preserved.Curre... by PeterKnoop 4 0 | 4 | 0 | |
| Open | Currently in the sidecar widget, you can only freeze the scrolling action in the media panel (by duplicating the same... by DavidMedeiros Frequent Contributor 2 1 | 2 | 1 | |
| Open | Hello!If we could have an ability to attach a PDF, Word Doc, or other type of text file that would be extremely helpf... by SaraJL Frequent Contributor 6 0 | 6 | 0 | |
| Needs Clarification | When using a Map Tour, it would be extremely helpful to have an option for either:Freezing (pinning) text above a Map... by KelseyBang-Olsen Emerging Contributor 0 1 | 0 | 1 | |
| Open | It would be great to filter a layer inside the StoryMap designer. Instead of creating duplicate layers in a web map, ... by C_McNamara Frequent Contributor 0 0 | 0 | 0 | |
| Under Consideration | I like the (new) feature in Storymaps to simply make an infographic. But when you want to incorporate an icon in the ... by MikeHorree Emerging Contributor 3 6 | 3 | 6 |
Idea Submission Guidelines
| User | Count |
| 11 | |
| 10 | |
| 4 | |
| 4 | |
| 4 |
