ArcGIS StoryMaps Questions
158
12M
1.2K
| Open | Having the ability to add TABLES to the Map Tour widget would be useful. As it stands, there is only the ability to a... by CaitlinParker2 Occasional Contributor 0 0 | 0 | 0 | |
| Closed | The shortcut for superscripts is ctrl + shift + [+], this should be improved because it does not work in all browsers... by MichaelAder Emerging Contributor 0 1 | 0 | 1 | |
| Open | Within Story Maps a popular option to introduce visual clarity is using a media action in order to filter a web map. ... by melissawidas Emerging Contributor 1 0 | 1 | 0 | |
| Open | In Esri StoryMaps, embedded maps allowed zoom in/zoom out with the mouse scroll wheel when your mouse cursor was over... by twilliamson_topv Occasional Contributor 0 0 | 0 | 0 | |
| Needs Clarification | Setting an initial map extent when a map tour is loaded. Currently when you have 1 point on a map tour the extent is ... by CaolanMulholland Emerging Contributor 2 4 | 2 | 4 | |
| Open | Please allow us to set an initial zoom extent on our web maps in map tours. It's great to have custom zoom on each po... by MGPGISUSER Emerging Contributor 2 0 | 2 | 0 | |
| Already Offered | interactive web map with ArcGIS OnlineJ'ai accédé à ArcGIS online , j'ai ajouté des couches à ma carte et finalement... by imanebenromdhane Regular Contributor 0 7 | 0 | 7 | |
| Under Consideration | Within a sidecar, I often put multiple maps centered on the same exact spot so when scrolling to another map the posi... by JamesPoeschel Frequent Contributor 4 3 | 4 | 3 | |
| Open | I recently had the idea for a storymap to automatically revert a map action back to the home view of the web map. For... by Casey_AITRC Emerging Contributor 0 0 | 0 | 0 | |
| Already Offered | We love the immersive Map tour, which gives unique options to show historical locations with guided field photos, tex... by cbp-geus Frequent Contributor 0 2 | 0 | 2 | |
| Open | I am creating a sidecar and would like to position the text to the left, and leave the legend open on the right side ... by MonicaAlmeida1 Occasional Contributor 3 0 | 3 | 0 | |
| Open | When updating web maps that I have created exclusively for StoryMaps, any additional layers I add do not appear autom... by EstherEliasson Emerging Contributor 1 1 | 1 | 1 | |
| Open | For the second time in a few months, a StoryMap that we've created starts prompting public users for an AGOL login af... by KatieGaut Frequent Contributor 4 0 | 4 | 0 | |
| Open | I often find it difficult to set an appropriate extent for maps within a storymap. Either the map is too small, or ... by HelenCooper Frequent Contributor 9 2 | 9 | 2 | |
| Under Consideration | When configuring a web map in Story Maps, grouped layers are treated as one single layer when setting the visibility.... by StijnVerlaar Occasional Contributor 18 11 | 18 | 11 |
Idea Submission Guidelines
| User | Count |
| 3 | |
| 1 | |
| 1 | |
| 1 | |
| 1 |
