Stories won't duplicate
2285
20
02-24-2023 07:02 AM
CeliaClifford
I can no longer duplicate StoryMaps (as I could before). I've tried doing so multiple browsers, and tried restarting both browsers and computer: no dice.
Specifically, when I click "duplicate," it goes to a screen that SAYS it's duplicating ... but that never actually happens. When I return to my projects, a new "Draft" copy has been made ... but when I click on it, it can't be opened.
This problem began yesterday and persists today.
I'd be grateful to learn how to fix this! Many thanks for any insights (or accounts of similar experiences).
3 Solutions
OwenGeo
Esri Notable Contributor
We have identified the cause of this issue and the plan is to address it in a patch currently scheduled for Monday.
For now, if you need to duplicate a story, you can ask your organization admin to do this for you as admin accounts are not affected by this issue. I apologize for the inconvenience.
Owen Evans
OwenGeo
@CeliaClifford -- This issue has been fixed. Please let us know if you are still having trouble duplicating stories.
Owen Evans
CeliaClifford
Thanks, Owen! I can duplicate again: hooray! 😀
OwenGeo
@CeliaClifford - Thanks for reporting this. We received one other report of this today, but so far we are not able to reproduce the issue ourselves.
Can you share your story publicly (from your ArcGIS content page) and send me the story ID so we can take a look? Is the story you are trying to duplicate your own story, or is it shared with you via a group?
Owen Evans
AleksandraPawelec
Could you have a look at my story @OwenGeo too please? The same issue with duplicating here. https://arcg.is/0Tu5qa0
Thank you in advance,
Aleksandra Pawelec
OwenGeo
@AleksandraPawelec -- We took a look at your story and don't see any reason it should present problems for duplication.
Can you share more information about the problem you are seeing? What steps are you following and what error do you encounter?
Owen Evans
OwenGeo
Owen Evans
CeliaClifford
That's amazing: thanks so much! I really appreciate the interim solution and plan for a quick fix too. 🙂
RoatanMarineParkRMP
Hi Own Geo,
I have the same problem. We can't duplicate our story
https://arcg.is/0bifnT
InstofMarineandEnvTech
Hi Owen,
We are also having trouble duplicating our story. Any help you could give would be appreciated.
Thanks!
OwenGeo
@RoatanMarineParkRMP@InstofMarineandEnvTech -- The issue mentioned elsewhere in this thread has been fixed, and we are not aware of any general issues with duplication at this time. I would recommend that you reach out to Esri Technical Support so they can help troubleshoot what is going on with your stories.
Owen Evans
CeliaClifford
Thanks for the quick reply OwenGeo!
The story I’m trying to duplicate is my own, yes. Duplicating worked earlier in the week, multiple times, so it’s a new problem.
Here’s a link to the story: https://storymaps.arcgis.com/stories/b76b0f56a0864900b38f0005a5dd1740
This is the ID: b76b0f56a0864900b38f0005a5dd1740
I’m really grateful for your support: thank you!
Leah
Hi CeliaClifford,
OwenGeo (Esri Notable Contributor) mentioned you in a post! Join the conversation below:
________________________________
Re: Stories won't duplicate<>
@CeliaClifford- Thanks for reporting this. We received one other report of this today, but so far we are not able to reproduce the issue ourselves. Can you share your story publicly (from your ArcGIS content page) and send me the story ID? Is the story you are trying to duplicate your own story, or is it shared with you via a group?
*** DO NOT REPLY TO THIS E-MAIL ***
Reply | Accept as Solution<> | Give Kudos<>
