There is a possibility to modify (or to implement in future versions) the Header text style, to have a part in Italic?
We need to create (lot of) StoryMaps where the title contain the name of the genus/specie of pests insects, and the scientific name is required to be written in italic, like:
StoryMaps for survey of Aromia bungii (Faldermann, 1835)
Thanks a lot.
Enrico
Solved! Go to Solution.
Yep! This is already possible. This enhancement was released in an update several months ago.
Hi Owen,
thank you for the reply, but I mean the MAIN header not the chapter heading.
We need, as example, to have the possibility to change only the name of the insect Aromia bungii in italic, leaving the other words in normal case. Selecting the text (as visible in the image below) no sub-menus appears giving the possibility to to modify the words.
Is this planned in next releases of the SM?
Thank you,
Enrico
