Images not loading/blurry in sidecar
1138
12-04-2023 11:35 AM
Labels (2)
CorineNoufi
When I preview my story map the images I have in my sidecar are not loading, they all show up blurred out. All the images are high-quality .png files. Any ideas what the problem is?
AbbyE_Esri
Hi @CorineNoufi , that blurred image is the loading state for the image, which means it should be eventually showing as a clear image. How long are you waiting on that Preview page for the images to load? It may take a moment for several larger images to load.
Are you seeing any variance in waiting times between different browsers?
--Abby
AbbyE_Esri
@CorineNoufi Please also feel free to share a link to your story if you're able!
--Abby
CorineNoufi
I thought that might be the case! So do you think using lower quality images would solve the problem? This is the link to my story: https://storymaps.arcgis.com/stories/fb15957145f842b988fee645d22ba075
AbbyE_Esri
@CorineNoufi , I think what may be best is actually adding an animation in the form of a GIF to several slides of a sidecar, and then adding the text you want to scroll through in the sidecar's narrative panel. That way you can scroll through the text, without having to compromise the quality of the images. This also has the added benefit of making the text more accessible and available to screen readers.
If you try this approach, you could create a GIF of the different animations and add it to one sidecar slide. You can then duplicate that slide, and add the different text to scroll through on each slide. That GIF will not jump as you scroll, which makes it easy for readers to scroll through the text at their own pace without worrying about the timing of the animation.
It is likely that the photos in their current state would end up loading in time for readers as they scroll, as long as they have a standard network connection. Just wanted to provide this other idea of using a GIF in case you wanted to try it out!
--Abby
