Can't remove title/header from story map
7207
10
06-29-2022 06:16 AM
MackenzieHickie
I am unable to remove the header/title section from my story map. I saw a previous post stating I am able to do so, but the option to click "hide header" is nowhere to be found. Can someone help me figure out how to completely remove the header/title? I am using my story map only for the guided map, and do not need any sort of title at all. Thanks!
OwenGeo
Esri Notable Contributor
@RossBrewer9830 - Thanks for posting. Just to clarify, you can hide the header without embedding by adding ?cover=false to the end of any story URL.
If you are looking for a setting similar to the "hide cover" one that controls visibility of the header, I would suggest that you please add your suggestion as an idea on the Ideas board so others can vote for it. It would also be helpful to share more details about how you expect to use and/or share the story so we can better understand how hiding the header will help you achieve what you are looking to do.
Owen Evans
