I'm looking to use raster calculator to select a range of slope values from a DEM and also exclude vertical changes that are less than 15 feet. Is there a script that would accomplish this? Thanks for any help.
Best,
Aaron Y.
To identify the areas where elevation difference, is 15 feet... assume you mean within 1 cell width
you will need to use a Focal Range
Focal Statistics (Spatial Analyst)—ArcGIS Pro | Documentation
You will have to set those to null, prior to calculating slope
Set Null (Spatial Analyst)—ArcGIS Pro | Documentation
Slope (Spatial Analyst)—ArcGIS Pro | Documentation
Since that may be a bit of a pain, you might want to just calculate slope, then identify the slope values where 15 feet/cell width is the threshold and set those to null
Perhaps a comment as to your end goal would provide alternate/supportive suggestions.
Hi Dan
Thankyou for those recommendation.
Ultimately we need a steep slope polygon that adheres to city code, which roughly stipulates that a steep slope qualifies if the percent rise is greater than or equal to 20% and the minimum elevation change is 15'
We will use the polygon layer to help evaluate zoning permits, building enforcement, etc.
slightly different problem then, you will need zonal values not local since your ultimate locations are polygons (eg lots, neighborhoods, site plans)
Zonal Statistics (Spatial Analyst)—ArcGIS Pro | Documentation
It may take generating a couple of rasters to get the values you need (eg range).
You can use site specific areas (eg clip the dem using a polygon/area/zone) and derive the values you need.
On that note and from experience, you will still have to look at the elevation values within the area (maybe a quick contour map) and any directionality in the slope and location of abrupt changes and spread of values within
Hi Yeaton,
From the conversation, I understand you would like to:
If this summary is correct, here’s one possible workflow you can follow (and later automate in a script):
Please give this a try and let me know if it produces the expected output.
While step 2 uses an approximation, I believe it should still be useful. If you need exact values, you may want to use a different approach using the Raster Cell Iterator.
Note: There may be other ways to achieve your goal. If I’ve misunderstood any part of your workflow or missed a detail, please let me know.
Tania
Hi Tania,
Thanks for the thorough workflow. I'm not that familiar with raster calculations, or writing scripts for that matter. For calculating the elevation change (in meters) would I use a Conditional operator? I tried the following expression but got an output raster with zero values:
Con(( "slope" == (meters/cell size)* 100), 1,0)
--Specifically--
-- Con(("slope" == (4.571910/.499773)*100), 1,0)
Thanks!
Aaron Y.
I wouldn't query for your exact threshold in the above equation, but one that is >=
Con(("slope" >= (4.571910/.499773)*100), 1,0)
will give those values greater than or equal your critical value and assign a value of 1, otherwise 0
Thanks Dan, I'll give that a try
Best,
Aaron
