How to distribute bank deposits, folowing the population of the area
1061
11-19-2012 04:41 AM
RobertoLopez
I am trying to "spread" the money deposited in a bank branch among the surrounding area. If I use the "density" funtion of Spatial Analyst, the deposits are spread circularly. But I want to spread them following the population in the area (the higher population, the higher the deposits).
Is there a way to do this?
(I am thinking in creating a proximity raster, with a cost distance defined as the inverse of population density. But it looks like a too convoluted way).
RamB
Use of "spatial weights matrix" will be of great help to you. see here
regards,
RobertoLopez
I have been trying to figure out how to achieve what I want with the help of your succinct advice. But I couldn't. The steps that I followed were:
1. First I researched what the "spatial weights matrix" was.
2. Then, I investigated which tools use it, and which of these tools can be used for my problem (distribute the amount of deposits among the population surrounding a branch).
The only tools that, I believe, can be used for my problem AND uses the "spatial weights matrix" was "Hot Spot Analysis (Getis-Ord Gi*)" (please, correct me if I am wrong). This tool can perform a hot spot analysis, that uses an spatial weight matrix.
3. Then, comes the task of creating the appropriate spatial weight matrix. As I want the distribution of bank deposits to follow the distribution of population, I thought that the most appropriate spatial conceptualization was to create a "cost distance" where the "cost" was the inverse of the population. This way, the deposits will spread farther in polygons more populated.
To built this "spatial weights matrix", I followed this steps:
     a. Convert the Census block polygons to a raster, using "population" as the value.
     b. Calculate the inverse of population for each cells, using the raster calculator. This was my "cost raster"
     c. Calculate a "cost distance" using the previous raster.
Here is the result:
[ATTACH=CONFIG]19811[/ATTACH]
     d. Here a get lost, as I don't know how to create the "input table" required by the "Generate Spatial Weight Matrix" tool.
Beside, this procedure is so convoluted that I have the feeling of being looking in the wrong direction.
Can you give me some advice?
RobertoLopez
Do you think that, in order to distribute a point feature among the surrounding population, I should look into "Heat Maps" tools  or more into "Interpolation" tools.
RL
RamB
May be a simple gravity formula can work ? to keep it simple !
money deposited = population in an area* accounts in bank / (distance between bank and that population area)
the result would mean, that closer and higher the population, more will be the deposits from that population.
regards,
RamB
Just edited the power function for deterrence, it is the basic gravity formula from physics book.
money deposited = population in an area* accounts in bank / (distance between bank and that population area)^2
regards,
