Con is empty - no result in python but in Map Algebra
1566
06-14-2021 05:28 AM
JohannesBierer
Hello,
I've problems with a Con command. In python there is only a empty result (no error message), but if I use Map Algebra  - raster calculator in ArcMaP there is a result? Version ArcGIS Desktop 10.6.1
What's wrong with the Con :
OutRas = Con((outClip > value2) & (outClip < value), outClip)
value2 is 0.1 m less than value in a dgm. For example Value: 907.1346 m und Value2: 907.0346 m
Any ideas? It's in line 64?
def ExpandSperren_1(self, outFC):
        myList = list()
        # outFC = Sperren_3D
        outLyr = "outLyr"
        arcpy.MakeFeatureLayer_management(outFC, outLyr)
        arcpy.AddField_management(outLyr, "POINT_Z_1", "DOUBLE") # , 10, 4)
        with arcpy.da.UpdateCursor(outLyr, ["POINT_Z", "POINT_Z_1"]) as cursor:
            for r in cursor:
                value = round(r[0], 4)
                print value
                r[1] = value
                cursor.updateRow(r)
        d = {}
        for r in arcpy.da.SearchCursor(outLyr, ["ORIG_FID", "POINT_Z_1"]):
            print r[0]
            d[r[0]] = r[1]
        for key, value in d.iteritems():
            # print value
            sel = "{} = {}".format("ORIG_FID", key)
            print sel
            arcpy.SelectLayerByAttribute_management(outLyr, "NEW_SELECTION", sel)
            result = arcpy.GetCount_management(outLyr)
            count = int(result.getOutput(0))
            print("Count is {}".format(count))
            value2 = value - 0.1
            print "Value: {} und Value2: {}".format(value, value2)
            # Select Basin
            BasinLyr = "BasinLyr"
            arcpy.MakeFeatureLayer_management(self.outBasin, BasinLyr)
            arcpy.SelectLayerByLocation_management(BasinLyr, 'intersect', outLyr)
            strR = round(value, 4)
            print strR
            ReplaceRstrR = str(strR).replace(".", "_")
            outClip = "clip_{}".format(ReplaceRstrR)
            arcpy.Clip_management("SperrenDGM", "", outClip, BasinLyr, "#", "ClippingGeometry", "NO_MAINTAIN_EXTENT")
            arcpy.CheckOutExtension("Spatial")
            OutRas.save("OutRas_{}".format(ReplaceRstrR))
            outFlood = value - OutRas
            outFlutung = Con(outFlood > 0, outFlood)
            outPut = "Zwischen_Height_{}".format(ReplaceRstrR)
            outFlutung.save(outPut)
            myList.append(outPut)
        self.outFLRaster = "AAA_FlHoehe_Gesamt_Kaltenbronn"
        arcpy.MosaicToNewRaster_management(myList, arcpy.env.workspace, \
                                   self.outFLRaster, "",\
                                   "32_BIT_FLOAT", "1", "1", "LAST","FIRST")
        arcpy.CheckInExtension("Spatial")
DavidPike
MVP Notable Contributor
I believe you'd have to cast outClip into a Raster object to use that map algebra syntax i.e. arcpy.Raster(outClip)
OutRas = Con((arcpy.Raster(outClip) > value2) & (arcpy.Raster(outClip) < value), outClip)
DavidPike
JohannesBierer
Thank you David, that worked!
