GIS Request Management Solution - Enterprise solution with no access to Survey123 Connect
1588
05-01-2025 01:33 AM
LaurenAlt
Hi all! I just discovered the GIS Request Management Solution, which may solve one of my biggest problems. I have deployed it on our Enterprise 11.3 (where all staff have access), but at this moment, I can only access Survey123 Connect with my AGOL account (where we only have very few licences, so not an option for company wide use).
I have tried to send the forms that need amending through our collaboration, but that doesn't seem to work. Does anyone have a workaround where I can get the form into Surver123, edit it and then get it back into our Enterprise version?
Thanks so much 🙂
BrandiRank22
Are you sure you can't access your Enterprise Portal in Survey 123 Connect?
Open Survey 123 Connect on your machine - make sure you have the latest version.
In the top right, click on your profile picture/icon, go to Settings.
Click add connection - add your portal address to connect.
RyanUthoff
MVP Regular Contributor
I might not be fully understanding your question, but if you're trying to share S123 forms with a distributed collaboration, then it's not supported. https://enterprise.arcgis.com/en/portal/11.3/administer/windows/share-content-with-collaboration-par...
But I still don't think I'm fully understanding. Are you trying to share forms between AGOL and Enterprise?
BrandiRank22
LaurenAlt
Thankyou so much! This worked perfectly. I can't believe I didn't see that option earlier. Cheers 😊
Hamg
You might also want to consider configuring the S123 site in your enterprise environment and share the forms through that site with your Enterprise members.
