Capital Project Coordination Solution - Editing/appending via Geoprocessing/pro
530
02-25-2026 08:09 AM
GeoFinn
We would like to implement the Capital Project Coordination solution but need the ability to import data from external sources. I attempted to append data to the "InfrastructureProjects" hosted feature layer. The append was successful in Pro but the data doesn't show in the apps or the hosted feature layer views. I am using the most current solution in ArcGIS Online.  I am able to add new projects using the Capital Project web editor tool (Capital Project Catalog) without issue.
Is anyone else using Pro/Geoprocessing to manipulate data in the Capital Project Coordination Solution?
AndyShoemaker
Hi There,
My first suggestion would be to check the data to make sure what has been loaded has all the same fields populated as what the Capital Project Catalog adds and populates.
Many of the views and apps rely filters set on specific fields to ensure the correct data is shown for each step in the workflow.
My guess is that some of these fields need to be populated to show up correctly. A simple field calc should take care of it.
Andy
Andy Shoemaker
