Access to previous Versions of Water Utility Network Foundation
353
02-06-2025 08:00 PM
JakemSchott
Hello All
I recently downloaded the Water Utility Network Foundation template from ArcGis Solutions - Water Utility Network Foundation the version of the template seems to be compatible for ArcGIS PRO 3.3 I am currently running version 3.1.2 is there any way to get an earlier version of this template. When I try to open this aprx file it advises Failed to open Map view
I tried adding layers from the geodatabase file to a new blank template map but doesn't seem to allow this to happen any advice or solutions
Thanks for any feedback
PatrickGCowan
The Water Utility Network Foundation is only supported on Pro 3.3+. There were some changes between 3.1 and 3.3 that are making it not work. At least part of the issue is the 64 bit object ids of the UN feature classes in the asset package that are making the map not display. 64bit object id's were not supported in 3.1, only 32bit object id's.
The suggested workflow would be to upgrade Pro to 3.3+.
