We have identified an issue displaying a scene view with the ArcGIS Runtime SDK for iOS and the ArcGIS Runtime SDK for .NET (Xamarin.iOS) on iOS 15.4 and 15.4.1. The issue affects iOS and iPadOS devices with an A14, A15, or M1 processor.
[ Update, Apr 13 2022: 100.13.2 released, addressing the fix for iOS and .NET (Xamarin.iOS / Xamarin.Forms-iOS) - see blog ]
[ Update, Apr 12, 2022: We are preparing an update to fix this issue, targeting release on April 13, 2022. ]
[ Update, Apr 5, 2022: We have identified and are assessing a candidate fix. ]
When displaying or interacting with a scene view, the scene view may become unresponsive, or the application may crash.
- 2D workflows (map view) are not affected.
- The ArcGIS Runtime SDK for Qt is not affected.
- Only ArcGIS Runtime SDKs version 100.13 and 100.13.1 are affected.
- ArcGIS Runtime SDKs version 100.12 and earlier are not affected.
- This issue impacts all applications that display a scene view.
- No workaround has been identified.
We are working to identify the root cause and deliver a fix as a top priority, but at present no ETA is available.
[April 5 2022] We have identified and are assessing a candidate fix.
The devices that are impacted are:
- iPhone 12, 12 Pro, 12 Pro Max, 12 Mini (2020, A14 Bionic)
- iPhone 13, 13 Pro, 13 Pro Max, 13 Mini (2021, A15 Bionic)
- iPhone SE 3rd Gen (2022, A15 Bionic)
- iPad Air 4th Generation (2020, A14 Bionic)
- iPad Air 5th Generation (2022, M1)
- iPad Pro 11" 3rd Generation (2021, M1)
- iPad Pro 12.9" 5th Generation (2021, M1)
- iPad Mini 6th Generation (2021, A15 Bionic)
The device must be running:
Earlier versions of iOS (15.3.1 and earlier) are not affected.
A sample stack trace is provided from iOS to help you identify if you are encountering this crash:
Thread 0 [Crashed]:
0 AGXMetalG14 0x1f17f1d50 0x1f1411000
1 AGXMetalG14 0x1f17f6028 0x1f1411000
2 Runtimecore 0x10a72824c esri::rendering_engine::GPU_device_metal::submit_command_(objc_object*, esri::rendering_engine::Command const&, esri::rendering_engine::Pipeline const*) + 1775
3 Runtimecore 0x10a7289e0 esri::rendering_engine::GPU_device_metal::submit_commands(esri::common::Span<esri::rendering_engine::Command, -1l>) + 67
4 Runtimecore 0x10a736b60 esri::rendering_engine::Device::submit(esri::rendering_engine::Render_pass&, esri::common::Span<esri::rendering_engine::Command_set, -1l>) + 83
5 Runtimecore 0x10a084914 esri::map_renderer_3d::View3D::draw(std::__1::shared_ptr<esri::rendering_engine::Device> const&) + 5023
6 Runtimecore 0x109938110 esri::geoview::Scene_view::draw(esri::geoview::Device&) + 143
7 Runtimecore 0x10967fb18 RT_GeoView_draw + 51
8 ArcGIS 0x1059d0280 -[AGSMetalGeoViewRenderer drawRequested] (AGSMetalGeoViewRenderer.m:102)
9 ArcGIS 0x105a084a0 _28-[AGSGeoView setRtcGeoView:]_block_invoke_2 (AGSGeoView.m:260)
10 ArcGIS 0x105a45198 drawRequestedHandler (RTCGeoView.m:298)
11 Runtimecore 0x10995aa28 $std::__1::function<void (void*)>::operator()(void*) const + 35
12 Runtimecore 0x10a868abc esri::common::signal_detail::Signal_base::notify_(esri::common::Function_ref<void (esri::common::signal_detail::erased_target_base&)> const&) const + 351
13 Runtimecore 0x1098ff140 esri::common::Signal<void (esri::geoview::Geo_view const&)>::notify(esri::geoview::Geo_view const&) const + 39
14 Runtimecore 0x109905a8c esri::geoview::Geo_view_draw_requested::draw_request_callback() + 43
15 Runtimecore 0x10a077cb4 esri::map_renderer_3d::Map3D::pulse() + 447
16 Runtimecore 0x109938024 esri::geoview::Scene_view::pulse() + 51
17 Runtimecore 0x109680be0 RT_GeoView_pulse + 27
18 ArcGIS 0x1059d01a4 -[AGSMetalGeoViewRenderer drawInMTKView:] (AGSMetalGeoViewRenderer.m:87)
19 MetalKit 0x1bd7096fc -[MTKView draw] + 183
20 MetalKit 0x1bd717fb8 -[MTKViewDisplayLinkTarget draw] + 39
21 QuartzCore 0x184bb31a0 CA::Display::DisplayLink::dispatch_items(unsigned long long, unsigned long long, unsigned long long) + 747
22 QuartzCore 0x184d0e0c4 CA::Display::DisplayLink::dispatch_deferred_display_links() + 347
23 UIKitCore 0x184140254 _setupUpdateSequence_block_invoke + 215
24 UIKitCore 0x183aba084 _UIUpdateSequenceRun + 83
25 UIKitCore 0x18413fcb0 $schedulerStepScheduledMainSection + 143
26 UIKitCore 0x18413f478 runloopSourceCallback + 91
27 CoreFoundation 0x180f2cf04 _CFRUNLOOP_IS_CALLING_OUT_TO_A_SOURCE0_PERFORM_FUNCTION__ + 27
28 CoreFoundation 0x180f3dc90 _CFRunLoopDoSource0 + 207
29 CoreFoundation 0x180e77184 _CFRunLoopDoSources0 + 267
30 CoreFoundation 0x180e7cb4c _CFRunLoopRun + 827
31 CoreFoundation 0x180e906b8 CFRunLoopRunSpecific + 599
32 GraphicsServices 0x19cf2a374 GSEventRunModal + 163
33 UIKitCore 0x1837f5e88 -[UIApplication _run] + 1099
34 UIKitCore 0x1835775ec UIApplicationMain + 363
