Map view IS panning or zooming
5864
9
08-27-2012 04:06 PM
FrankLin1
ArcGIS Runtime SDK for iOS v2.3 provides "panning" & "zooming" in "AGSMapView" for deciding whether mapView is panning or zooming , but how can I use them ?
Frank
NimeshJarecha
You cannot use them. It's just for information purpose only.
Regards,
Nimesh
FrankLin1
But how can I update something like label when map is panning...
NimeshJarecha
Could you please elaborate what you are trying to achieve?
Regards,
Nimesh
ChristopherEbright
MapView posts notifications on panning and zooming, you can register for them with this:
[[NSNotificationCenter defaultCenter] addObserver:self selector:@selector(scaleDidChange:) name:@"MapDidEndZooming" object:nil];
[[NSNotificationCenter defaultCenter] addObserver:self selector:@selector(mapDidEndPanning:) name:@"MapDidEndPanning" object:nil];
then implement the callback methods (these are your own custom methods):
-(IBAction)scaleDidChange:(NSNotification *)notification {
   //do Something here
-(IBAction)mapDidEndPanning:(NSNotification *)notification {
   //do Something here
Is this what you were looking for?
FrankLin1
   //do Something here
   //do Something here
Sorry , I'm looking for the MapView "panning" not "End Pan".
I have some UILabel added to the AGSMapView as subview , and I wanna update the label's positon when the map is panning , rotating and zooming . So I'm looking for some methods exactly called when the AGSMapView is panning.
FrankLin1
Regards,
Nimesh
I just want to show graphic symbol (Annotation) on the Map View , but I found no way to do a good job.
If I use AGSGraphicsLayer to add graphic , and subclass the AGSMapView to catch it's touch methods , when it's rotating , I have to update the GraphicsLayer by called "datachanged" , it gave a bad performance.
If I use UILabel to present the text symbol , and added to the AGSMapView as sub view , it will have a good performance when rotating , but when panning , particularly when user swipe to pan , I have no way to catch the panning operation so I can't update the label after swipe panning.
If I use the AGSDynamicLayerView to add the UILabel by:
UIView<AGSLayerView> *myDynamicLayerView = [self.mapView addMapLayer:[AGSGraphicsLayer graphicsLayer] withName:@"..."];
[myDynamicLayerView addSubView:myUILabelView];
It did a good job to attach the baseMap when swipe to pan , but when zooming or rotating , I have to do a complex transform to UILabel.
...So , any way else ?
Please help me...
Thanks
Frank Lin
DiveshGoyal
KVO to the rescue!
You should attach a key-value-observer (KVO) to the panning/zooming properties of the mapview.
When these properties toggle ON/OFF, your observer will automatically be informed. You can use that to update the text label.
More info on KVO here : http://developer.apple.com/library/mac/#documentation/Cocoa/Conceptual/KeyValueObserving/KeyValueObs...
FrankLin1
KVO to the rescue!
Hi ~ Have you ever tried to use KVO for panning/zooming ?
I implement the following code in the sub class of AGSMapView when touch ended.
- (void)begin2log{
    preVisibleArea = self.visibleArea;
    NSLog(@"%@",self.visibleArea);
    NSLog(@"%d",self.panning);
    NSLog(@"A %d",self.animating);
    [super touchesEnded:panTouches withEvent:panEvent];
    while (self.visibleArea != preVisibleArea) {
        NSLog(@"YES");
    while (self.animating) {
        NSLog(@"YES");
    NSLog(@"%d",self.animating);
    NSLog(@"End");
By these code , I found panning/zooming is just the info when touch begin , and after the swipe touch end (and the map is panning), the map view's visibleArea/panning/zooming immediately changed , but the map is still panning .
By double check the API document , I found map view has a property named animating , and this is what the property I'm looking for , but when I track this property , the map view stops animating panning/zooming.
I guess in the SDK , the code holds panning/zooming is just an animation.
Does Esri plan to put ArcGIS Runtime SDK for iOS on the Github so that we can develop it together and make it better ?
Thanks for your reply
  Best regards
  Frank Lin
FrankLin1
KVO to the rescue!
By implement following code , nothing happens.
- (void)viewDidLoad
    [super viewDidLoad];
    //Init
    AGSTiledMapServiceLayer *serviceLayer = [AGSTiledMapServiceLayer tiledMapServiceLayerWithURL:[NSURL URLWithString:@"http://services.arcgisonline.com/ArcGIS/rest/services/World_Street_Map/MapServer"]
    [self.mapView addMapLayer:serviceLayer withName:@"Hello"];
    //KVO
    [self.mapView addObserver:self
                   forKeyPath:@"panning"
                      options:(NSKeyValueObservingOptionNew | NSKeyValueObservingOptionOld)
                      context:NULL];
                   forKeyPath:@"zooming"
                      context:NULL];
- (void)observeValueForKeyPath:(NSString *)keyPath
       ofObject:(id)object
                        change:(NSDictionary *)change
                       context:(void *)context {
    //if panning changed
    if ([keyPath isEqual:@"panning"]){
        NSLog(@"Panning");
    //if zooming changed
    if ([keyPath isEqual:@"zooming"]){
        NSLog(@"Zomming");
