How to show the callout on click of AGSDynamicServiceMapLayer?
1041
09-13-2012 09:28 PM
Sunitapatil
I am adding four AGSDynamicServiceMapLayer in map view.Those AGSDynamicServiceMapLayer contains feature layers How to call out on click of those features on DynamicServiceMapLayer.
NimeshJarecha
You can click on feature of either AGSGraphicsLayer or AGSFeatureLayer to show the callout. For dynamic map service layer, you should do following...
1. Add a AGSGraphicsLayer.
2. Implement AGSMapViewTouchDelegate and implement mapView:didClickAtPoint:mapPoint:graphics: method.
3. Execute either AGSQueryTask or AGSIdentifyTask with tap location (mapPoint) on dynamic layer.
4. The result of task will be graphics layer.
5. Set symbol and infoTemplateDelegate on each graphic and add all graphics to graphics layer.
6. Show callout by executing showCalloutxxx method on AGSMapView.
You can look at Identify Task Sample.
Regards,
Nimesh
NimeshJarecha
Regards,
Nimesh
Sunitapatil
Thanks.........
But it is showing callout for one feature layer from one dynamic map service layer. And I want to show the callout on every layer Then how we do this with every layer?
Please tell me how to do this.....
NimeshJarecha
You'll have to execute task against each layer.
Regards,
Nimesh
