I didn't find a way to move elements in the API, so I made one
1177
05-26-2024 07:30 PM
pengpengdeng
package com.maptool.map;
import android.util.Log;
import com.esri.arcgisruntime.geometry.AngularUnit;
import com.esri.arcgisruntime.geometry.AngularUnitId;
import com.esri.arcgisruntime.geometry.AreaUnit;
import com.esri.arcgisruntime.geometry.AreaUnitId;
import com.esri.arcgisruntime.geometry.GeodeticCurveType;
import com.esri.arcgisruntime.geometry.Geometry;
import com.esri.arcgisruntime.geometry.GeometryEngine;
import com.esri.arcgisruntime.geometry.GeometryType;
import com.esri.arcgisruntime.geometry.ImmutablePartCollection;
import com.esri.arcgisruntime.geometry.LinearUnit;
import com.esri.arcgisruntime.geometry.LinearUnitId;
import com.esri.arcgisruntime.geometry.Point;
import com.esri.arcgisruntime.geometry.PointCollection;
import com.esri.arcgisruntime.geometry.Polygon;
import com.esri.arcgisruntime.geometry.Polyline;
import com.esri.arcgisruntime.mapping.view.GraphicsOverlay;
import com.esri.arcgisruntime.mapping.view.MapView;
import com.esri.arcgisruntime.mapping.view.SketchCreationMode;
import com.esri.arcgisruntime.mapping.view.SketchEditor;
import com.esri.arcgisruntime.mapping.view.SketchGeometryChangedEvent;
import com.esri.arcgisruntime.mapping.view.SketchGeometryChangedListener;
import com.esri.arcgisruntime.mapping.view.SketchStyle;
import com.maptool.config.MapConfig;
import java.util.ArrayList;
import java.util.Collections;
import java.util.List;
* 图斑平移
public class GeometryMove {
private static SketchEditor mainSketchEditor;
private static SketchStyle sketchStyle;//以前的样式
private static Geometry optNewGeomety;//记录移动的地块
private static Geometry tranGeometry;//记录移动的老地块
private static GraphicsOverlay mHighlightGraphicsOverlay;
private static MapView mapView;
private static GeometryChangedListene geometryChangedListene;
* 平移地块
public static void moveGeometry(MapView mMapView, Geometry moveGeometry) throws Exception {
tranGeometry = moveGeometry;
mapView = mMapView;
mainSketchEditor = mMapView.getSketchEditor();
if (mainSketchEditor == null) {
mainSketchEditor = new SketchEditor();
} else {
sketchStyle = mMapView.getSketchEditor().getSketchStyle();
mainSketchEditor.setSketchStyle(MapConfig.getTtansparentSketchStyle());
mMapView.setSketchEditor(mainSketchEditor);
mainSketchEditor.start(SketchCreationMode.FREEHAND_LINE);
//加载单个图斑高亮显示图层
mHighlightGraphicsOverlay = new GraphicsOverlay();
mapView.getGraphicsOverlays().add(mHighlightGraphicsOverlay);
geometryChangedListene = new GeometryChangedListene();
mainSketchEditor.addGeometryChangedListener(geometryChangedListene);
* 获取移动后的图斑
* @return
public static Geometry getMoveGeometry() throws Exception {
closeMoveGeometry();
if (optNewGeomety != null) {
return optNewGeomety;
} else {
return null;
* 移动图斑关闭
public static void closeMoveGeometry() throws Exception {
mainSketchEditor.stop();
mHighlightGraphicsOverlay.getGraphics().clear();
if (sketchStyle != null) {
mainSketchEditor.setSketchStyle(sketchStyle);
if (geometryChangedListene != null) {
mainSketchEditor.removeGeometryChangedListener(geometryChangedListene);
public static class GeometryChangedListene implements SketchGeometryChangedListener {
@Override
public void geometryChanged(SketchGeometryChangedEvent sketchGeometryChangedEvent) {
if (mainSketchEditor.getSketchCreationMode() == SketchCreationMode.FREEHAND_LINE) {
Polyline polyline = (Polyline) mainSketchEditor.getGeometry();
Iterable<Point> partsAsPoints = polyline.getParts().getPartsAsPoints();
List<Point> listPoint = new ArrayList<>();
for (Point point : partsAsPoints) {
listPoint.add(point);
if (listPoint.size() > 0) {
* 1、拿出画的流状线的最后一个点坐标
Point clickPoint = listPoint.get(listPoint.size() - 1);
* 计算需要移动图形的中心点坐标与流状线最后一个坐标的方位角
double azimuth1 = GeometryEngine.distanceGeodetic(tranGeometry.getExtent().getCenter(), clickPoint,
new LinearUnit(LinearUnitId.METERS), new AngularUnit(AngularUnitId.DEGREES),
GeodeticCurveType.GREAT_ELLIPTIC).getAzimuth1();
PointCollection points = new PointCollection(mapView.getSpatialReference());
points.add(clickPoint);
points.add(tranGeometry.getExtent().getCenter());
Polyline polylineLength = new Polyline(points);
* 计算需要移动图形的中心点坐标与流状线最后一个坐标的距离
double length = GeometryEngine.lengthGeodetic(polylineLength, new LinearUnit(LinearUnitId.METERS), GeodeticCurveType.GREAT_ELLIPTIC);
// 输出滑动距离和方位角
Log.e("滑动距离", length + "");
* 获取需要移动的面要素的所有点
ImmutablePartCollection parts = null;
List<Point> listPolygon = new ArrayList<>();
boolean polygonTaget = false;
if (tranGeometry.getGeometryType() == GeometryType.POLYGON) {
Polygon polygon = (Polygon) tranGeometry;
parts = polygon.getParts();
polygonTaget = true;
} else if (tranGeometry.getGeometryType() == GeometryType.POLYLINE) {
Polyline polygon = (Polyline) tranGeometry;
} else if (tranGeometry.getGeometryType() == GeometryType.POINT) {
Point point = (Point) tranGeometry;
listPolygon.add(point);
if (parts != null) {
if (parts.size() > 1 && polygonTaget) {
List<List<Point>> AllListPolygon = new ArrayList<>();
for (int i = 0; i < parts.size(); i++) {
Iterable<Point> points1 = parts.get(i).getPoints();
for (Point point : points1) {
listPolygon.add(GeometryEngine.moveGeodetic(point, length, new LinearUnit(LinearUnitId.METERS),
azimuth1, new AngularUnit(AngularUnitId.DEGREES), GeodeticCurveType.GEODESIC));
AllListPolygon.add(listPolygon);
List<Geometry> listGeometry = new ArrayList<>();
List<Double> doubles = new ArrayList<>();
for (List<Point> list : AllListPolygon) {
PointCollection polygonList = new PointCollection(mapView.getSpatialReference());
polygonList.addAll(list);
Polygon polygon1 = new Polygon(polygonList);
double geodetic = GeometryEngine.areaGeodetic(polygon1, new AreaUnit(AreaUnitId.SQUARE_METERS), GeodeticCurveType.SHAPE_PRESERVING);
listGeometry.add(polygon1);
doubles.add(geodetic);
optNewGeomety = GeometryEngine.union(listGeometry);
Double max = Collections.max(doubles);
int i = doubles.indexOf(max);
for (int j = 0; j < listPolygon.size(); j++) {
if (i != j) {
optNewGeomety = GeometryEngine.difference(optNewGeomety, listPolygon.get(j));
} else {
Iterable<Point> partsAsPointsPolygon = parts.getPartsAsPoints();
for (Point point : partsAsPointsPolygon) {
* 需要移动的面要素的所有点向上面计算的方位角,距离整体移动
List<Point> list = GeometryEngine.moveGeodetic(listPolygon, length, new LinearUnit(LinearUnitId.METERS),
azimuth1, new AngularUnit(AngularUnitId.DEGREES), GeodeticCurveType.GEODESIC);
optNewGeomety = new Polygon(polygonList);
optNewGeomety = new Polyline(polygonList);
optNewGeomety = list.get(0);
MapConfig.highlightGeometry(optNewGeomety, mHighlightGraphicsOverlay);
Ting
by Esri Regular Contributor
Thanks for posting this topic! In the new GeometryEditor API, there is a method to achieve this functionality - moveSelectedElement.
Ting
