How to add feature layer into fragment?
3583
07-03-2015 04:53 AM
giangnguyen
I just add successful a tilesmapserviceslayer and a feature layer into activity. However, when i do this in fragment, it can't work.
Here is my code:
package com.niit.giangnguyen.tree_manager;
import android.app.Fragment;
import android.graphics.Color;
import android.os.Bundle;
import android.view.LayoutInflater;
import android.view.View;
import android.view.ViewGroup;
import com.esri.android.map.MapView;
import com.esri.android.map.ags.ArcGISFeatureLayer;
import com.esri.android.map.ags.ArcGISTiledMapServiceLayer;
import com.esri.core.geometry.Envelope;
public class HomeFragment extends Fragment {
    public MapView mv = null;
    public HomeFragment(){}
    @Override
    public View onCreateView(LayoutInflater inflater, ViewGroup container,
                             Bundle savedInstanceState) {
        View rootView = inflater.inflate(R.layout.fragment_home, container, false);
        Envelope env = new Envelope(105.50485954224524, 21.04870508156068, 105.75256390997109, 21.09248760188878);
        mv = (MapView)rootView.findViewById(R.id.map);
        mv.addLayer(new ArcGISTiledMapServiceLayer(
                this.getResources().getString(R.string.basemap_url)));
        mv.setMapBackground(Color.WHITE, Color.MAGENTA, 0, 0);
        mv.addLayer( new ArcGISFeatureLayer(
                "http://172.20.10.6/hanoi/rest/services/Hanoi/Cay/FeatureServer/0",
                ArcGISFeatureLayer.MODE.SNAPSHOT));
        return mv;
And here is my layout
<?xml version="1.0" encoding="utf-8"?>
<RelativeLayout xmlns:android="http://schemas.android.com/apk/res/android"
    android:layout_width="match_parent"
    android:layout_height="match_parent">
    <com.esri.android.map.MapView
        android:id="@+id/map"
        android:layout_width="fill_parent"
        android:layout_height="fill_parent"
        mapoptions.center="34.056215, -117.195668"
        mapoptions.ZoomLevel="16">
        <com.esri.android.map.ags.ArcGISFeatureLayer
            Url="http://172.20.10.6/hanoi/rest/services/Hanoi/Cay/FeatureServer/0"
            mode="SNAPSHOT" />
    </com.esri.android.map.MapView>
Help me to solve this problem please. thanks!
EricBader
Honored Contributor
Hello!
When you say "It can't work", can you explain what the experience is? Can you attach the stacktrace?
Thank you.
