Identify Routes widget showing field names and domains displaying both code and value
239
10-07-2025 11:48 AM
LPlamondon
Hi everyone,
We built a Roads and Highways network in ArcGIS Pro 3.3 and published it to ArcGIS Enterprise 11.3. Using the Esri template, we created an Experience Builder app.
I’m encountering two issues with the out-of-the-box Identify Routes widget:
The Attributes section displays field names instead of field aliases. I can’t find an option in Experience Builder to switch to aliases. Is there a configuration setting or workaround for this?
For fields with coded value domains, the widget shows both the code and description (e.g., C1 - C1). Is there a way to display only the description or the domain value?
Any guidance or suggestions would be appreciated!
Thanks in advance,
