Batch Renaming of Routes
Hello everyone, Recently, we were given a new jurisdictional boundary and new county and local jurisdiction abbreviations that our agency is adopting as the official standard. Our RouteID field for our local road LRS (we don't have Route Name field used in our LRS yet) has <County>_<Local Jurisdiction>_<Route name i.e.…
Event Editor functionality in LRS Widgets/Experience Builder
Please add "Event Replacement" functionality previously available in Event Editor to LRS Widgets/EB. Please add "Retire edited events and create new events effective Today" functionality previously available in Event Editor to LRS Widgets/EB.
Roads and Highways-Experience Builder Add Point Event Coordinate with option to capture coordinate from Map click
In Roads & Highways, we would like to have Experience Builder set up with Add Point Event --'Coordinate method' with option to capture coordinates from Map click point. Not sure if this can be done by using widgets in experience builder. This functionality existed in "event editor" as Adding point events by coordinate…
ArcGIS Pro 3.5.8 and ArcGIS Server 11.5 patch 3 now available
ArcGIS Pro 3.5.8 and ArcGIS Server 11.5 patch 3 are now available for download. These patches include multiple Pipeline Referencing fixes along with other general Esri issues addressed. For more information on Pro 3.5.8, see https://links.esri.com/ArcGISPro/3.5/IssuesAddressed and download the patch on MyEsri. For more…
ArcGIS Pro 3.5.8 and Server 11.5 patch 3 now available
ArcGIS Pro 3.5.8 and ArcGIS Server 11.5 patch 3 are now available for download. These patches include multiple Roads and Highways fixes along with other general Esri issues addressed. For more information on Pro 3.5.8, see https://links.esri.com/ArcGISPro/3.5/IssuesAddressed and download the patch on MyEsri. For more…
Incorporate Structure Line into APR
The what's new documentation as linked below describes the enhancement of incorporating pipeline devices and junctions into the UN for use in overlay events. We would like to see that expanded to Structure Line. Key regulatory requirements exist that rely upon knowing whether a segment of pipe is cased. Adding structure…
View only Fields in Attribute Sets w/ UN features
I would like to see an option in configuring attribute sets for a user to incorporate view only fields into the segmentation that present in the dynamic segmentation layer as view only. For example, if a user were to have a dedicated event layer for projects they were planning, it would be nice to have the tool pre-segment…
Explore ArcGIS Roads and Highways Activities at UC 2026
Esri User Conference 2026 is just around the corner. Interested in a curated list of activities for ArcGIS Roads and Highways? Review the attached flier.
Esri UC 2026: ArcGIS Pipeline Referencing Activities
Going to the Esri User Conference (July 13–17) in San Diego, California? Explore ArcGIS Pipeline Referencing activities at the event, including showcase presence, technical workshops, industry-focused sessions, special interest group meetings, and customer presentations. Download the attached flier for a quick overview.
Switch From and To Measures of an Event Using Attribute Rules
Hi, I need some help determining if it's possible to switch the from and to measures of an event using an attribute rule. Here's the situation. I have two linear event layers, one is used for storing work order information and a second event layer stores attributes used to populate the the work order events. When a user is…
ArcGIS Pro 3.3.8 and ArcGIS Server 11.3 ArcGIS Pipeline Referencing/ArcGIS Roads and Highways Patch 3 now available
ArcGIS Pro 3.3.8 and ArcGIS Server 11.3 ArcGIS Pipeline Referencing/ArcGIS Roads and Highways Patch 3 are now available for download. These patches include a broad set of bug fixes for Pipeline Referencing tools, along with fixes to other tools and capabilities throughout ArcGIS Pro. You can download the ArcGIS Server…
What's new in ArcGIS Roads and Highways and ArcGIS Pipeline Referencing: May 2026
The ArcGIS Pro 3.7 and ArcGIS Enterprise 12.1 releases of ArcGIS Roads and Highways and ArcGIS Pipeline Referencing focus on reducing manual effort in editing workflows, extending the web-based editing experience, and deepening the integration with ArcGIS Utility Network and the Address Data Management solution. Blog…
APR User Group Members
Hello! I am setting up my own team and had a run around trying to understand this site. So, if you are looking for a map/guide/tips to get information, I hope this helps! Here is how you sign up for the user group meetings: ArcGIS Pipeline Referencing | User Group Meeting APR Community Homepage: ArcGIS Pipeline Referencing…
Create LRS Event From Existing Dataset not saving using ArcGIS Pro 3.3.7 (Pipeline Referencing)
We are Registering Events using Create LRS Event From Existing Dataset. (Pipeline Referencing) Using ArcGIS Pro 3.3.7 and doing configuration in FGDB. Running the GeoProcessing Tool is successful and Feature Class displays in LRS Hierarchy. However, properties show it is not registered with LRS. If we save project and exit…
Locate by Intersection
I work for a rural municipality with a road network based on the Dominion Land Survey (grid roads). It's a very common practice to refer to projects based on their proximity to an intersection of Range Roads and Township Roads. Some functionality that would be great to see is a "Locate Intersection" tool in Roads and…
Create Multi-Route Events
Something my organization would love to see is the ability to create a single line event along multiple routes. One example of when this would be used is applying calcium chloride to gravel roads for dust suppression -- the residence may be near an intersection, and dust suppression is required on both the N/S road and the…
Use Subtypes for Event Layers in Experience Builder
Hello, I would like to use a layer containing subtypes as an event layer (linear or point). I have configured my layers and then published my web service using symbology based on the subtype. In ArcGIS Pro, I have no problem; I can add these layers as a subtype layer group. The "Add Event" tool treats them as individual…
ArcGIS Pipeline Referencing Server 11.5 patch 2 now available
The ArcGIS Pipeline Referencing Server 11.5 patch 2 is now available for download. This patch is designed to be installed with the recently released ArcGIS Pro 3.5.6 patch. These patches will provide fixes to issues that were identified by early adopters of 3.5/11.5 and is designed for users that can't move to 3.6/12.0…
Roads and Highways Server 11.5 patch 2 now available
The ArcGIS Roads and Highways Server 11.5 patch 2 is now available for download. This patch is designed to be installed with the recently released ArcGIS Pro 3.5.6 patch. These patches will provide fixes to issues that were identified by early adopters of 3.5/11.5 and is designed for users that can't move to 3.6/12.0 yet.…
Experiencing severe performance issues on Oracle SDE Branch Versioning
I'm an IT GIS support person for my org and not a Roads and Highways expert, so I don't have deep knowledge of LRS or even Branch versioning, but... We have an Oracle SDE Branch Versioned Roads and Highways implementation. We do a lot of offline replicas in Field Maps. We also have a few non-LRS-related layers in that…
Plotting to LRS using two different start and end route IDs
Hi all, I am trying to create a single polyline on our LRS where the start point is on one Track (one route ID) and the end point is on another track (a different route ID). This is common when we are taking a track out of service and use bounds from one signal to another that might have traveled over a turnout. My thought…
Dynamic Segmentation allows for current time only
The dynamic segmentation should have the option to make the output for just current time as opposed to all time only, then having to use a query to only show the current time in the output table.
ArcGIS Pipeline Referencing User Group Meeting – November 18, 2025
Thank you for attending and participating in the ArcGIS Pipeline Referencing User Group Meeting held on November 18, 2025! Summary of topics covered: * Call for presentations at ERGIS 2026: The deadline is Dec 1, 2025 * Current releases and patches* See the What’s New in ArcGIS Roads and Highways and ArcGIS Pipeline…
What’s New in ArcGIS Roads and Highways and ArcGIS Pipeline Referencing: November 2025
The ArcGIS Pro 3.6 and ArcGIS Enterprise 12.0 releases bring new capabilities and quality of use improvements to ArcGIS Roads and Highways and ArcGIS Pipeline Referencing users. These enhancements are designed to streamline compliance reporting workflows, simplify the data loading process, and save time for common…
Roads and Highways migration from ArcMap to ArcGIS Pro 3.6
Enclosed is the latest version of the white paper outlining the steps to migrate a Roads and Highways LRS geodatabase from ArcMap to ArcGIS Pro 3.6. There are no major changes between the 3.5 version of the white paper.
