Invalid JSON Primitive using applyEdits
2221
09-27-2023 12:15 PM
MichaelKohler
Trying to use applyEdits to a hosted feature service in ArcGIS Online. I went to the query endpoint for the individual layer and queried out a feature which returned the features json for a single feature.
 "features" : [
      "attributes" : {
        "OBJECTID" : 62428,
        "ADDID" : 63649,
        "LONGITUDE" : "-20.39381937",
        "LATITUDE" : "57.21860018",
        "geoy" : 111.95,
        "geox" : 170,
        "ISSHELLADDRESS" : 0,
        "SHELLID" : 0,
        "DuplexID" : 63650,
        "ADDRESSWITHUNIT" : "WhAt NOW MaN",
        "ISSHFA" : 0
      "geometry" :
        "x" : 170.00002741069,
        "y" : 111.9500441551
I can take this, minus the "features" tag, and stick it in the updateFeatures for that individual feature layer and it works.
Then I put the same content in a format for the applyEdits like below, and it fails.
    "id" : 0,
    "adds" : [],
    "updates": [
        "geometry": {
          "x" : 170.0069,
		  "y" : 11.9500
        "attributes": {
			"OBJECTID": 62428,
			"ADDID": 63649,
			"LONGITUDE": -80.39381937,
			"LATITUDE": 27.21860018,
			"geoy": 111.95,
			"geox": 970,
			"ISSHELLADDRESS": 0,
			"SHELLID": 0,
			"DuplexID": 63650,
			"ADDRESSWITHUNIT": "It's Me I am the problem",
			"ISSHFA": 0
    "deletes": []
I have tried multiple permutations with the larger format by removing the adds and deletes leaving just the updates and it's the same thing. I get back "code" : 400... Unable to apply edits. Other times it will show the Invalid JSON Primitive in "edit"
I'm sure, like most times, I'm just missing something simple here.
Thanks as always!
pslgisAdmin
I knew it was something stupid! I had run into this well over 5 years ago with our address database when I created a GIS Services.DLL for the other app devs to use.
We are moving the address app from WPF to Angular, so apparently, I had to run through the same gauntlet! I've requested them to not make them string fields in the new table.
I seem to remember you helping me out on something before and I see you on here in a lot of posts. Thank you so much for your efforts.
jcarlson
Hard to know for sure, but it's probably just submitting the wrong type to one of the fields. Although, that's usually a 500 code. In your example, "LATITUDE" and "LONGITUDE" are strings in the query, but floats in the update. Is that right?
Are you including a token in your update request? If the layer isn't publicly editable, you'll need one.
- Josh Carlson
Kendall County GIS
jcarlson
Regarding tokens: that applies if you're hitting the REST endpoint using a POST request. If you're doing this from the services directory, it handles the token in the background once you log in.
- Josh Carlson
Kendall County GIS
pslgisAdmin
