Extract/query the data in a fetureclass
1403
05-27-2022 01:10 PM
René_AstadDupont
Probably a very simple question...
I want to use the attributes / data in a feature class in a C# program.
The data is located in a Enterprise SDE database.
How do I query all the data from a feature class?.
What does the url look like.
( I have managed to querry for at Token) but cant figure out how to get a list of records in the feature class.
Raul_Jimenez
Hi René,
I guess you mean through the REST API, right?. If the feature class has been published as a FeatureLayer you have a query operation.
Here a couple of resources:
In both cases the URL is pointing ArcGIS Online, you just need to change it to the right server.
Hope this helps.
Raul_Jimenez
Hi René,
Hope this helps.
René_AstadDupont
Thank you Raul. Yes indeed the Query made the trick in the end. Documentation was just a little overwhelming at a firs glance and seemed to be very map centric, were I just needed the attributes.
