Attachment URL timing out after 'x' amount of requests
861
05-31-2011 04:49 AM
Drew
I am having issues with Attachments and am unable to figure out what???s causing the issue.
I created a Flex Widget to view, add and remove attachments and it works fine, but once you view about 20 attachments the attachment URL starts to timeout. I have examined this using Firebug.
Even if I just call you attachment URL directly from my browser it will fail after I request it about 20 times.
Does anyone have any ideas what might be causing this. It seems to be AGS related.
I should note that my attachemtns is a jpg and stored as image/jpeg - mine type is also added in the agsoutput virtual directory, i can watch the images being written to the output directory too.
RaviNarayanan
Andrew, it should not timeout after 20 requests. If this continues to be an issue, please contact ESRI Support so it can be investigated further.
