Publish map resource to work correctly with Adobe Flash Builder
1434
05-24-2011 01:28 PM
RajKailasan
I have stored my .mxd in a shared folder called C:\Inetpub\wwwroot\
arcgis\rest\services\samplemxd in the ARCgis server(version 10).
  I am publishing a GIS resource called samplemxd.mxd from this folder
through arcgis server manager.It gets published to a url:
http:\\servername\arcgis\services\samplemxd\mapserver.
  How can I get it published to the url: http://servername/ArcGIS/rest/services/SampleMXD/MapServer which is the way Adobe Flash Builder requires it(within the rest folder)?
RaviNarayanan
Raj,
Once the service is published you should be able to access it via the REST endpoint.
http://servername/arcgis/rest/services/samplemxd/mapserver.
if the service is not listed here and it is running, make sure the REST cache is cleared from here:
http://servername/arcgis/rest/admin/cache/clear (login using a user that is a member of agsadmin user group)
Ravi
