Make able to delete unnecessary objects from the Project tree
1311
08-01-2023 12:31 PM
Status: Implemented
ÁkosHalmai
This new, project tree on the left is great, however If I create for example a reconstruction I run it, then I have to create another one, it is impossible to remove the first, unnecessary one. No delete button, no right click & delete.
Same with the alignments: if I create two or three alignments with different settings, I run them and finally I choose the best one, it is impossible to remove the others.
Similar to the Geometries: If I add a RoI it is impossible to remove it, once added.
Thank you & Best regards,
Ákos Halmai
5 Comments
FelixRohrbach
Thank you for voicing this request! The removal of elements that have previously been added to the project tree is indeed a feature that we are currently looking into. Some items might need some special consideration as the data could already be in use by some of the following workflow steps. We hope though that we can work out a good user experience and bring this soon into one of our following releases!
ÁkosHalmai
Thank you! Just an addition for the removal: If there is a finished reconstruction, it would be nice to have a local menu option to remove the intermediate and temporary data created by the process, because next to the results there is lot of other data, probably unnecessary for the user, because he/she already finished the procedure.
FelixRohrbach
The upcoming ArcGIS Reality Studio 2024.3 release will allow removing of items in your project tree that are not used in other elements.
ÁkosHalmai
Thx! We definitely will use it.
FelixRohrbach
Happy to announce that Reality Studio 2024.3 has been released and now allows to remove items from the project tree.
