Viewing attribute data in Quick Capture
1512
03-13-2023 01:03 PM
CHSnowman
Hi all,
Does anyone know of a way to set up Quick Capture (currently on Portal 10.9.1, soon to be on 11.0) so that when the user taps on a submitted line in the Quick Capture Mobile App map, they can see the length of the line? I've got a ${lengthMI} variable set up in a field, but I'm having trouble finding a way to alter the pop-up to get the viewer to see it.
Thanks in advance!
JohnathanHasthorpe
Hi - The length value calculated by the variable will be written to the captured record, but will not be visible in the QuickCapture app.
One approach would be to use a link button to launch a web map. The user could then tap the feature and see the popup.
Note that the feature would need to be sent/uploaded to QuickCapture in order for it to be visible in the web map.
CHSnowman
Thanks for the workaround. Unfortunately our collection area is offline so it won't be applicable to our workflow, but I do appreciate the clarification.
