QuickCapture project from a template
2630
6
06-05-2022 01:20 AM
AngelikaKotsafti
Hello! I am totally new here. I created a QuickCapture project from a template. As I saw, a layer was created automatically, so I assumed that all the collected data will go there. However, even though I collected data in my mobile phone and I can see them in the map of the app, I cannot send them from the mobile device. They are stucked there. Why did I do wrong? Was there a procedure I needed to follow before I go and create directly the QuickCapture project from the template?
JohnathanHasthorpe
Hi Angelika
You correct. It is expected that records should get submitted to the layers created with the template.
Could you share the template that you are using and I'll take a look?
Also, in the app, if you capture a feature, then open the map and press the send button, what happens? Does the feature send?
Thanks
John
AngelikaKotsafti
Dear John, thank you for your answer. When I am trying to send the data from the app, it says "sending..." and after a while this dissapears and there is the same notification "Records on device: 31" and then the button "send". I am using the "Run, Walk, Have Fun" template https://www.arcgis.com/home/item.html?id=4bd155366bf94b8a9dcf6ff0c592bb40
Mandy_Li
Hi @AngelikaKotsaftihere is something you can try:
  1. Open the layer item(s) that the new project is submitting data to (If created from templates, it's the mobile view of the source feature layer).
  2. Go to layer settings.
  3. Check on "Enable editing", "Keep track of changes to the data" and Save. If already checked, please untick, save, tick on, and save again.
  4. Now try to send the data again from the mobile app, it should go through.
Let me know if it works. Thanks!
AngelikaKotsafti
Dear Mandy,
Thank you for your answer. I followed your instructions but it still doesn't send my data.
I am attaching a screenshot.
Mandy_Li
@AngelikaKotsafti I thought it may be a layer issuer but looks like it's an issue on the mobile app based on your description at https://community.esri.com/t5/arcgis-quickcapture-questions/quickcapture-project-from-a-template/m-p... will look into this. Thanks!
If possible, can you share the project with the product team? You can do this by creating a group and invite user: QCCreator, and then share the QuickCapture project (including map and layers) with that group.
AngelikaKotsafti
Thank you for your help. I am going to try this!
