Pull data from map in Quickcapture
1331
07-21-2023 09:12 AM
djcrouse
I have a custom basemap with a feature layer. Is it possible to pull data from the map layer into QC? It is a stream layer and I want the name, WBID, reach length, etc. to autopopulate the Quickcapture questions. So the user will have their location in relation to the stream data they are collecting. (I can do it in Field Maps using Arcade to intersect a buffer of the streams, but want to keep the big button, user-friendliness of QC)
Debby
JohnathanHasthorpe
Hi - you would need to use an Arcade expression in order to do this. You could perform an intersect between the captured point and the buffered streams.
This functionality is available in beta.
Please go to the Early adopter community to find out more.
JohnathanHasthorpe
