Thankyou Randall Rebello for your response.
>>>How did you create this layer?
Workflow
I have used tools from the toolbox: ManageOrientedImagery
1 I have first made a Oriented Imagery catalog. After that i have add the images (from my local) in the oriented imagery catalog (OIC). (see the settings of the tool below)
2 Edit the properties of your OIC using a geoprocessing tool.
3 Create coverage features, which represent the coverage of each image on the map.
4 Create a coverage map, which is a vector tile package file of the coverage features created in the last step.
Finally i have publisched the layer as feature layer in ArcGIS online with the tool Publisch Oriented Imagery Catalog, where i can open it in Quick Capture. In Quick Capture was a feature layer avaiable
I have used the next source for the workflow:
https://doc.arcgis.com/en/imagery/workflows/tutorials/creating-an-oriented-imagery-catalog.htm
>>>You can use things like onedrive but you will have to make sure your images public. The path has to be added to the image field in the attribute table of the Oriented Imagery Catalog. The path to the images need to be accessible at all times and should be a direct path to the image. The site that you are using to share the images should also have download permissions. Our recommendations for cloud based storage is Amazon S3 or Azure. The other thing you can do is add the images as attachments to the OIC layer.
Amazon S3 or Azure is not possible for me, because it is not free
I want to use it with dropbox
How can i make a connection with arcgispro and the webfolder of dropbox?
I want to open my dropbox folder (from web) in the ArcGIS catalog
