Change status or deleting a collected feature
869
06-19-2024 01:04 AM
MariaBonderupPedersen
Hi.
Hi.
Does anyone know if it is possible to create a collection and then later remove the collections again?
The case is that I have an employee out to collect some errors in the area. Later I have other contributors out there fixing the bugs, can I somehow remove these first collections or get them to change status?
AndreasHall
QuickCapture can not be used to edit data as far as I know. You should look at using Field Maps instead. You can consume the data collected with QuickCapture in Field Maps.
