Deep Learning Packages in Quick Capture
692
06-20-2024 06:39 AM
rrhee_bcfpd
Has there been previous discussion on the integration of ESRI DLPKs in Quick Capture similar to Survey123? Or has anyone else had success in finding an effective method for running DLPKs or other object detection pre-trains on images collected in QuickCapture?
The only workaround I can think of is publishing a python script tool as a geoprocessing service on Portal (or host a script out of an AWS web service instance) and running a webhook integration through Power Automate to hit the geoprocessing service endpoint using an http request, but I'm wondering if DLPK integration is coming soon, and sitting tight would be a better plan. We would rather not have to stand up and manage a machine for a Portal or an AWS instance if we don't have to, and would strongly prefer that the DLPK be loaded onto and run from the local device, as we don't want to lose flexibility in offline workflows.
