Can the Project User Input value display in a captured point popup be turned off?
1255
03-04-2022 02:05 PM
ToddTurner
I have 40+ buttons for an inspection project.  All but 4 buttons use the value of a Project User Input for the Priority value: High or Normal (from a field domain).  For the 4 buttons, the Priority value is hard coded to the value High, no matter what the Project User Input value is set to.
When a point is captured, but not yet sent, there are aqua map markers for those points. When you tap on an aqua marker you get a popup which shows the button name that was pressed, how long ago it was captured, what the Project User Input value was when captured, and a Delete button.
Having the Project User Input value display there is troublesome for our users.  When the Project User Input value is set the Normal, but they've tapped a High priority only button, the popup shows Normal. That's because the Project User Input value was Normal when the point was captured. But the Priority value captured for the point is High (those 4 buttons are set that way), and that proves out in the backend data.  The user thinks something is wrong; they forgot to set the PUI button to High, or the program isn't working.  In reality, all is fine. But the visual contradiction causes consternation.  Is there a way to remove the PUI value from that popup?
JohnathanHasthorpe
Hi Todd, this is not supported. Could you raise it as an idea through: https://community.esri.com/t5/arcgis-quickcapture-ideas/idb-p/arcgis-quickcapture-ideas
MeganEngel
@ToddTurner I have started the idea here: https://community.esri.com/t5/arcgis-quickcapture-ideas/allow-authors-to-configure-qc-pop-up-visible...
This is something I have been thinking about for a couple months now, glad I saw this post.
