Arcade expression: $map not recognised
2433
02-13-2025 01:14 PM
FrankHerbert
I'm getting a new error message that has never happened before. Please help!
In January 2025, I published a QuickCapture project for offline use. The user carries out a brief survey, and the new point feature is intersected with a vector polygon layer from the project MMPK. The vector polygon layer is very simple - just five regions covering the country, and the name of the intersecting region is passed to the new point feature. Here is the expression:
var regions = FeatureSetByName($map, "Regions");
// Filter the features where 'Type' is 'Ops'
var filteredRegions = Filter(regions, "Type = 'Ops'");
// Find intersections with the filtered feature set
var GEOGRAB = Intersects($feature, filteredRegions);
if (Count(GEOGRAB) == 1) {
  return Text(First(GEOGRAB).Region);
} else {
  return "NA";
I was able to publish the project, and it still works to this day in the field. I am trying to replicate the process for a separate project and that's when I noticed I couldn't publish the expression. I receive this error message:
Test execution error: Compilation error - Line : 1, 31: Identifier not recognized. Verify test data.
So there's is something wrong with the $map identifier, but I'm not sure what it is.
It might be worth mentioning, to publish the expression last month, I needed to use a dummy web map that was a replica of the MMPK. This allowed me to publish the expression and subsequently swap out the web map for the MMPK. This is a know bug to ESRI hence why I used this workaround.
Perhaps ESRI have released an update that will not let me publish the expression... I'm not sure.
Any help/advice would be appreciated.
FrankHerbert
FYI this has been solved. Case closed!
FrankHerbert
JasonBennett
What happened? I'm having a similar issue.
JasonBennett
FrankHerbert
When you add the project basemap,  just make sure to save and then refresh the QC project. Otherwise, QC doesn't seem to realise there's a project basemap containing the layers you want to query. Once you have done this, it will recognise the $map function in the expression and stop throwing out error messages
