Update failure via attribute rules with arcade
6222
12
04-01-2021 10:10 AM
ZhiyongHong
Our team is trying to use Arcade to do some data updates without success and I have reduced the update to be the simplest possible. Basically, this is to copy the data to 'notes' when this field changed. I am on pro 2.7 and I am using file geodatabase. Could anyone see what is wrong with this arcade expression or do I need to configure something for update via arcade? Thanks in advance for any helps! Following are the screenshots of the error we received and the arcade expression.
ZhiyongHong
Yeah, that is why we have to use the edit/update of the arcade. Our case (wording in your model) is that we need to detect the change in centreline_assets(trigger, giver) and push the change to watermain (receiver). We define the rule in centreline_assets and I think the only way for this to work is to use edit/updates from arcade. Not sure how to use a second trigger for this. Do you know an example of such kind of scenery?
SarahHartholt
I have not used arcade edit/updates
ZhiyongHong
I accepted one of the above comments from @SarahHartholt as a solution since her approach should be the right way to go to update a different field in the same feature. To update a field in a different feature using the "Edit" in the payload, the trick here is to edit on the "Attribute Rule" to trigger the rule, which will display a very nice message to tell us exactly what to do: there is a checkbox need to be enabled.
