Populate MakeValueArray() for Spatial Analyst Kriging
1312
09-07-2022 07:24 PM
JeromeHaaland
Is there any system for populating the parameters of a MakeValueArray()?
Below... the MakeValueArray() is populated correctly... except for the SemiVariogram properties.
protected override void OnClick()
            var progDlg = new ProgressDialog("Running Geoprocessing Tool", "Cancel", 100, true);
            progDlg.Show();
            string inputPointFeatures = @"C:\Temp\Learn.gdb\points";
            string zValueField = "zField";
            string outputRaster = @"C:\Temp\Learn.gdb\output";
            string semiVariogram = "Ordinary Spherical 3 200 100 0";
            string outputCellSize = "1";
            string krigParameters = "Variable 4 150";
            string outputVariance = "";
            string tool = "C:\\Program Files\\ArcGIS\\Pro\\Resources\\ArcToolBox\\" +
                              "toolboxes\\Spatial Analyst Tools.tbx\\" + "Kriging";
            var parameters = Geoprocessing.MakeValueArray(inputPointFeatures, zValueField,
                outputRaster, semiVariogram, outputCellSize, krigParameters, outputVariance);
            Geoprocessing.OpenToolDialog(tool, parameters);
            progDlg.Hide();
Tags (1)
GKmieliauskas
Spherical already means Ordinary. Look here:
https://pro.arcgis.com/en/pro-app/latest/tool-reference/spatial-analyst/kriging.htm
You can check all parameters starting that tool directly from ArcGIS Pro. After execution right click in history window and copy python script. It must be like this below:
out_surface_raster = arcpy.sa.Kriging(r"C:\Temp\Learn.gdb\points", "zField", "Spherical 3,000000 200,000000 100,000000 0,000000", 10, "VARIABLE 12", None); out_surface_raster.save(r"C:\Temp\Learn.gdb\output")
GKmieliauskas
JeromeHaaland
Thank You... That is exactly the system that I was looking for.  It works well.
